<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Redshift Glass Shows up as black]]></title><description><![CDATA[<p dir="auto">Hi Dr Sassi, I have 4 glass objects in my scene, 2 render fine, but the other 2 objects which are very thin just render black.</p>
<p dir="auto">Is there a way to render super thin glass objects?</p>
<p dir="auto">In Octane I think I needed to adjust the ray epsilon to fix similar problems, not sure what to do in Redshift though.</p>
<p dir="auto">Or could it just be dodgy geometry? It seems clean to me.</p>
<p dir="auto">Or maybe something in the material? The same material works on the other objects.</p>
<p dir="auto">Thanks again</p>
<p dir="auto">https://we.tl/t-bsiqOLxhcc</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/975/redshift-glass-shows-up-as-black</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Nov 2026 21:47:57 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/975.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 19 Feb 2024 06:03:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Redshift Glass Shows up as black on Mon, 19 Feb 2024 21:58:27 GMT]]></title><description><![CDATA[<p dir="auto">Great that is works for you, MaverickMongoose.</p>
<p dir="auto">My best wishes</p>
]]></description><link>https://cineversity.forums.maxon.net/post/3477</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3477</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Mon, 19 Feb 2024 21:58:27 GMT</pubDate></item><item><title><![CDATA[Reply to Redshift Glass Shows up as black on Mon, 19 Feb 2024 20:48:07 GMT]]></title><description><![CDATA[<p dir="auto">doh,I swear I tried that and it didn't work, maybe I had the wrong thing selected.</p>
<p dir="auto">Works great now, thanks again!</p>
]]></description><link>https://cineversity.forums.maxon.net/post/3473</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3473</guid><dc:creator><![CDATA[MaverickMongoose]]></dc:creator><pubDate>Mon, 19 Feb 2024 20:48:07 GMT</pubDate></item><item><title><![CDATA[Reply to Redshift Glass Shows up as black on Mon, 19 Feb 2024 07:16:06 GMT]]></title><description><![CDATA[<p dir="auto">Hi MaverickMongoose,</p>
<p dir="auto">Thank you for the files.</p>
<p dir="auto">The black glass shows up based on wrong Normals, which is an easy fix.<br />
Select the object and use the Polygon mode for this. With the "mouse" in the editor view, select all (cmd + a)<br />
Then go to Main Menu&gt; Mesh&gt; Normals&gt; Reverse Normals—one time.</p>
<p dir="auto">Repeat this for the other object.</p>
<p dir="auto">(This works here as all Normals are "wrong" in the same way; otherwise, use the Align Normals first. This function uses the first polygon as orientation; if that isn't working directly, use the process from above afterward.)</p>
<p dir="auto">Here is the result when I do it this way.</p>
<p dir="auto"><img src="/assets/uploads/files/1708326963321-screen-shot-2024-02-18-at-11.10.10-pm-resized.jpg" alt="Screen Shot 2024-02-18 at 11.10.10 PM.jpg" class=" img-responsive img-markdown" /></p>
]]></description><link>https://cineversity.forums.maxon.net/post/3457</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3457</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Mon, 19 Feb 2024 07:16:06 GMT</pubDate></item></channel></rss>
