<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Attaching a rigid body onto cloth motion]]></title><description><![CDATA[<p dir="auto">I have the fabric strap that is on snow goggles and there are hard plastic pieces to adjust the straps at the back.  I'm looking to have those straps float around in 0 gravity and have those plastic pieces attached to the dynamic moving strap.  I was struggling to find info about attaching objects to cloth, seems to always be the other way around.  Thanks in advance.</p>
<p dir="auto">https://www.dropbox.com/scl/fi/datzzwjcz06q3cb59m0dm/Sassi_Strap.zip?rlkey=qmjss1yl9ma6d9aht4q2thihs&amp;dl=0</p>
]]></description><link>https://cineversity.forums.maxon.net/topic/993/attaching-a-rigid-body-onto-cloth-motion</link><generator>RSS for Node</generator><lastBuildDate>Sun, 08 Mar 2026 04:51:36 GMT</lastBuildDate><atom:link href="https://cineversity.forums.maxon.net/topic/993.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 22 Feb 2024 22:43:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Attaching a rigid body onto cloth motion on Fri, 23 Feb 2024 06:39:35 GMT]]></title><description><![CDATA[<p dir="auto">Hi nopopoch,</p>
<p dir="auto">I'm often torn between simulation/dynamics and manual animation. Hence, I checked which one might work better. Sometimes it is a mix.</p>
<p dir="auto">The main question would be whether splitting the headband into three parts would be the better solution. Inside the Hard-Plastic elements, perhaps just a modeled strap part is static.</p>
<p dir="auto">As a side note, the hard plastic parts may need some attention. Optimize them to get it in one piece, then use the Remesher and have for each object. They can't be connected as one object if they need to float in space.</p>
<p dir="auto">I have set up two simplified scenes.</p>
<p dir="auto">Each uses a Vertex Map to define areas with more or less bendiness.</p>
<p dir="auto">The idea in the file "02" was to use the Connector as stabilization based on two elements that will not be shown.<br />
A torus here represents the Hard Plastic part. I'm not confident that this is the best way to go. I see it as "swimming".</p>
<p dir="auto">The file "11" also used the stabilization square as a Belt base. I have used just a Vibrator Tag here to create the motion.<br />
This allows for a more direct art direction, which is a priority for me. But yes, the band itself works as well as Cloth.</p>
<p dir="auto">Here are the two files; I'm sure there are a few more options and combinations. But I hope that helps you find your favorite setup.</p>
<p dir="auto">https://stcineversityprod02.blob.core.windows.net/$web/Cineversity_Forum_Support/2024_PROJECTS_DRS/20240222_CV4_2024_drs_24_SLhb_02-11.zip</p>
]]></description><link>https://cineversity.forums.maxon.net/post/3533</link><guid isPermaLink="true">https://cineversity.forums.maxon.net/post/3533</guid><dc:creator><![CDATA[Dr. Sassi]]></dc:creator><pubDate>Fri, 23 Feb 2024 06:39:35 GMT</pubDate></item></channel></rss>
