    cloth simulation streches to infynity
    Site Issues
    • S
      struggle-following last edited by
      Im trying to do a cloth simulation of a cape but when I render it, the Cape stretches to infynityalt text, Can someone can tell me what Im doing wrong?
        Hi struggle-following,
        Please open another post to get access to the Q&A forum. Thanks you.
        This forum here is not supposed to be a Q&A backdoor.
        I'm not familiar with the URL you have provided. I'm super careful with URLs, and just clicking on them is not an option.
        Sorry, but I try to keep it safe for everyone. If that was a project file, please attach it directly (as ".c4d" and below 1MB) or use Dropbox, Google, Adobe, Apple, or Wetransfer as a cloud server. Thank you.
        If it was an image, please share the project file instead. Images typically do not tell a lot. (Parameters, project settings, etc, all of that is not in an image.)
        I'm happy to look into the file.
        • S
          struggle-following last edited by struggle-following
          here is a wetrasfer link with the c4d file
          https://we.tl/t-WybIH0Ghdf
            This post is deleted!
              Thanks for the file, struggle-following!
              The mesh was super dense, and the typical rule of thumb is that the smaller the polygons, the less stiff things are.
              The cape was also double-surface, which is unnecessary, as the Cloth Object can add thickness.
              To demo the mesh density, I used the Remesh with 1% and created a low-res mesh. I left anything else as it was. Have a look: (I checked it in R25 and in 2024. Those are two different "engines", both versions are below)
              https://stcineversityprod02.blob.core.windows.net/$web/Cineversity_Forum_Support/2023_PROJECTS_DRS/20231031_CV4_R25-2024_drs_SIcd_01.zip
              You can dial in more density with the Cloth Object, which is added after the Simulation, and it works so much faster.
              • S
                I appreciate your help thanks
                  You're welcome, struggle-following.
                  Please check with the admins why you cannot access the Q&A forum. This forum is for site issues only. Thank you.
                  My best wishes with your project.
                  • Locked by  Dr. Sassi Dr. Sassi
