    line selection problem
    selection request
    • S
      south-brilliant last edited by Dr. Sassi
      Good morning,
      after updating to cinema 4d 2024.3.1 (and continue with 3.2) on windows 11, i have a problem with the select rectangle command in edges mode.
      if I select only a row of lines of a solid it selects others that have nothing to do with the selection and others that should be included are not there
      my selection is made from above and only for the horizontal row of lines, as can be seen from the other views instead some lines were randomly selected by cinema
      After the update I'm having a lot of problems....
        Hi, south brilliant,
        This feels like Tolerant Selection is on, but your screen shot shows it is off.
        I just answered a question that might be connected somehow. But sadly, I have no solution for that.
        Thanks for pointing out that you are on Windows, as I saw it elsewhere also mentioned to appear running Windows. I have problems recreating it on Mac.
        Since your model looks more complex than two cubes, I can look into it; please just use the object as a c4d file. Thank you.
        I'm unsure if that pushes anything forward, but if you would like to check, please get in touch with tech support.
        Sorry for the extra effort.
        My best wishes
