    Swapping Icons in C4D2024
    • M
      MAVEO last edited by
      My goal is that the Deadline Plugin has its own Icon, so it looks a bit nicer in the UI.
      In 2023, I know that the icons are in a TIFF and have a TXT File that assigns IDs. I also saw that 2024 changed that structure and put everything into this resource.zip file which I am unable to change without Cinema not starting anymore.
      Is there another way to change the icons? I also found a Icon Pack with missing Icons, that got lost during the transition from R23 to R25 which I also like to build in again.
      Thanks in advance.
        Hi MAVEO,
        Please have a look here:
        https://cineversity.forums.maxon.net/post/4134
        I have mixed results so far. If the problem persists, please check with tech support.
        https://www.maxon.net/en/support-center.
