    [Help] Introduction to UVs and BodyPaint
    Tutorial Discussions
    uv edit grayed out cinema 4d c4d body paint 3d
    • M
      maxonadmin last edited by Dr. Sassi
      View Tutorial
      • Other
      • D
        door-bedroom last edited by
        @ 7:24 the option "Set UVW from projection" is greyed out.
        • D
          using cinema 4D 2023
            Hi door-bedroom,
            The only way I can find to have it grayed out is when the object in the Object Manager is not selected.
            If that is not helping, can you share more information?
            Besides that, it is sometimes a good idea to open a new project and explore a problem freshly.
            • D
              It was selected but after a closer look I was missing something Make Editable(C). After selecting the object and clicking make editable "Set UVW from projection" lit up thanks.
                Thank you very much, door-bedroom,
                Yes, I should have mentioned that.
                  OFF_TOPIC
                  Just testing, as someone reported this is locked.
                  • Referenced by  Dr. Sassi Dr. Sassi
