    Paper dynamics
    • E
      evidence-due last edited by
      Hi everyone,
      I’m trying to recreate a confetti effect in Cinema 4D 2026 and I’m struggling to get the motion to feel believable.
      What I’m aiming for is not just confetti falling down, but a look more like a real burst of paper pieces:
      dense release at the top
      pieces rotating and fluttering while they fall
      slowing down in the air before reaching a certain lower area
      gradually settling, without looking like they hit an invisible hard collider
      Right now I’ve tried mainly with a Cloner + Rigid Body setup, using winds, drag, lift, damping, random rotation, and slightly varied confetti shapes. I also tested particles, but I’m still not getting that natural “paper-like” motion where the pieces seem to float, wobble and lose speed in a convincing way.
      My main problems are:
      the pieces often fall too much like rigid cards instead of light paper
      they do not rotate/flutter in a natural enough way while descending
      it is hard to make them visually slow down before a certain area without it looking like they are colliding with an invisible object
      if I use a controlled cloner layer to fake part of the effect, the transition can look too abrupt
      So my questions are:
      Would you approach this with rigid bodies, particles, cloth/soft body, or a hybrid setup?
      What is the best way to get that “paper flutter” behavior in C4D?
      How would you make the confetti slow down in the air before reaching a lower area, without a visible collision feel?
      If using a hybrid method, how would you blend a simulated layer with a cloner-controlled layer in a natural way?
      Any advice, workflow suggestions, or examples would be massively appreciated, especially from anyone who has done this kind of ad-style confetti shot before.
      Thanks a lot.![alt text](![image url](![image url](![image url](![C_1.png](Image dimensions are too big) image url))))![C_2.png](Image dimensions are too big)
      • noseman
        noseman last edited by
        Go to this link and find two setups in the "confetti" folder. Hope they help you get started:
        https://maxonvfx.com/c4d_quicktips_projects
