    [Help] Mixing Animation & Simulations
    Tutorial Discussions
    • M
      maxonadmin last edited by
      View Tutorial
      • Other
      • W
        weekend-cap last edited by
        Hey! 7.55, just after inverting the vertex map field, when I run the sim, the blinds fall down with gravity. Just before inverting, when the simulation is just affecting the top bit, the simulation seems to work fine and the blinds don't drop. It's only after applying the inversion. Any help greatly appreciated 🙂
          Hi weekend-cap,
          Thanks for the timestamp!
          Please have a look a the file below.
          https://www.dropbox.com/s/45oiow7imzu4q8n/CV4_2023_drs_23_ANct_01.c4d.zip?dl=0
          Is this working for you?
          I have no Project-file from your side, so I have no idea what the setup is. Perhaps the file above can clear the setup. I have done this in 2023.1; as usual, I never rely on past data, and things might have changed. So, this is a fresh new file.
