    C4D UI, RS Camera and AE
    redshift after effects rs camera incompatible cineware
    • R
      road-education last edited by Dr. Sassi
      I get that the RS camera tag is getting phased out and provided with its own RS Camera object but AE is crashing when I import my scene to retrieve cam data. I don't get access to regular C4D camera unless I change the render engine in the render settings. Any way I can make it so that I can have the regular C4D camera button/icon present when in RS is active? I put the icon in my UI and its greyed out and when I am done editing the palette it dispersal because I am in RS mode not standard or physical.
        Hi road-education,
        I have since long started a request to bring the RS Camera Tag back for various reasons. I have heard too many complaints about missing it.
        Please contact support, and share your findings.
        Perhaps enter to the "Share Your Idea."
        Both can be done here
        Would you mind trying this workaround?
        The Standard Camera and the RS camera have different ideas about how to define the sensor size. This might be typically fine, but it defines, in the real world, how much of the lens field of view is taken. Since I'm not aware of your project settings: please test this before going into production.
        https://stcineversityprod02.blob.core.windows.net/$web/Cineversity_Forum_Support/2023_PROJECTS_DRS/CV4_2023_drs_23_AEcm_01.zip
        I hope this problem is soon solved, as it should be no problem to bring this RS Camera Tag back.
        Again, sorry about the problem.
        Cheers.
