    [Help] Creating a Net Using Rope Simulations
    Tutorial Discussions
    • M
      maxonadmin last edited by
      View Tutorial
      • Other
      • P
        principle-ticket last edited by
        Hello! Thanks for the amazing instruction. At 15:23, I have added 19 Intermediate Points in the Radial line spline, and have re-created via the connector, but now my net is so floppy, that upon pressing play, I have what looks like a basketball net; the inner circle never gets close to its original size. I've double checked all steps and the gravity value (-981 cm), and wonder if there are different default simulation settings for Cinema 4D 24.5.1 that might be causing this. Thanks in advance! Benjamin
        • P
          Ahh! My inner/outer intermediate points were inadvertently set to 9... That was the problem!
            Thank you very much for updating your question, principle-ticket.
            I hope the series is enjoyable!
            My best wishes
