    Adjusting Modeling Axis is undoing work
    tech-support
    • B
      BigRED last edited by Dr. Sassi
      I have a weird one here. I used a clients flat art to create a packaging box. I am "folding" the box by selecting the polygons for each face of the box and rotating. I will use the modeling axis to adjust the x, y, and z so I can rotate from the proper position. Occasionally as I use those sliders, it will undo what I previously did. Its like I am hitting control z to undo or clicking undo in the upper left corner. Once that happens I can't click redo in the upper left corner to fix. I am using version 2023.1.3 on a PC in windows 10. Project attached. Appreciate any help. Thank you!
      New_8pack_Box.c4d
        Hii Big RED,
        Thanks for the file.
        I can do whatever I want, and the app is not taken away my work (like the mentioned CMD-Z-effect). But I'm not on Windows.
        Sorry, I can't reproduce it here, so tech support is the best next step. If there is a problem, it should be fixed.
        I hope it doesn't take too long, as we just released a new update; I assume the traffic is a little bit higher right now. Thank you.
        P.S.: I assume you are talking about the polygons, not that the axis jumps back (Retain Changes: Check)
        • B
          Dr. Sassi,
          Thank you for your reply. Correct, when I slide the modeling axis the polygons will jump back to their previous state. I have a screen recording of this but it is too large to add here. I will contact tech support. Thank you!
            You're welcome, BigRED.
            I hope the tech support has a solution for you.
            If I get something that isn't working as I think it should, I open a new project file and start from scratch. If that doesn't work, I restart the whole thing. Yes, that should not be needed, but being a tester of our software, this is the best way to check if something is reproducible, which is an important step toward solving it down the road.
            My best wishes!
