    connect muscle end to bone?
    joint muscle mesh deform
    29900
      Hi Craig,
      Thanks for asking; I had some good meetings, which always elevates my mood. Let's try to elevate yours as well.
      The max image height is set to 500 pixels.
      How did you create the muscle? Is it generator based or a polygon? Please share a little bit more.
      How did you create the muslce.
      • C
        channel-blame last edited by
        The muscle is made of polygons, as are the other models , all relevant anatomy is in a null, which has a subdivision tag. I just discovered ( yea me ) I need to bind the models to "bind" the joints, but it is not working for me, would love to solve this ;( but I'm not being successful at this -please tell me what other info I can provide you with, thank you, Craig
        • C
          BTW, if I "pin the points", that means I am using simulation/dynamics, but all I want to do is rotate the mandible with the bottom part of the muscle attached, and the top part of muscle attached to the top part of skull, my only solution might be to posemorph?
          • C
            I am experimenting; I may have to posemorph/with points the muscle, and manually rotate the mandible, so far this is the best that I can do, so at least I am trying, and learning, ;)-CZ
              Hi Craig,
              Here is a one-minute crash course in Bind/Weighting.
              https://stcineversityprod02.blob.core.windows.net/$web/Cineversity_Forum_Support/2023_Clips_DRS/CrashCourseWeighting.mp4
              The joints could be just child objects of the two parts (skull and jaw)
              The PoseMorph idea would require having the Bone parts in the mix to keep it in sync.
              Cluster objects (you would need at least two; it might be a way, but it needs to be weighted anyway. So, no advantage.
              • C
                thank you for your efforts, I will try this, but, the top part of the skull and mandible are two separate objects, would I need to put the joints and model in a null to make this work?-thanks you, Craig
                  Hi Craig,
                  I have separated the Joint hierarchy in the file below, not as a suggestion of best practice, but to demo the function.
                  CV4_2023_drs_23_ANsm_01.c4d
                  Joints are nothing else than objects that move points around.
                  Polygon objects are based on Points; when those points are moved, we move the edges and, consequently, the polygons. As a result, the mesh gets deformed.
                  If two or even more Joints influence a certain area, it is typical that each influences the system a little bit differently. This is the weighting.
                  This must always be, with no exception, 100% in total. Sadly that is often not explained why, other than it needs to be 100%. If it is less than 100%, even the slightest bit, a moving forward caharter would leave these parts more or less behind. If it is more than 100%, those parts are moved fast forward.
                  We have sadly no movie younger than ten+ years that shows that.
                  https://www.cineversity.com/vidplaytut/weight_painting_part_1
                  I encourage presenters to show it. But well, Bret, the master (I mean it as I say it here!), does this with no effort after 05:30 [min: sec]
