    Using fields to blend (fade) in diferent colors
    redshift vertex color
    • W
      walk-chain last edited by Dr. Sassi
      I am trying to use several fields to define colors that fades in on each other on a single mesh object, I also have to have it working in Octane render. I have tried using mograph effectors to get some colors but in vain.
        Hi walk-chain,
        Please have a look here:
        https://stcineversityprod02.blob.core.windows.net/$web/Cineversity_Forum_Support/2023_PROJECTS_DRS/20230413_CV4_2023_drs_23_RSvc_01.c4d.zip
        The XPresso in the scene is only to have the icon Color match the Field Color, so it is more accessible to work with those.
        If you have more than one object that uses the same material, then the Vertex Color Tag must have the same name.
        • W
          Thank you for your answer!
            You're very welcome, walk-chain.
            Please explore as well the Color Vertex Map.
