    Architron Plugin for C4D Empty Menu Buttons
    architron gui plugin
    • D
      deep-sea last edited by Dr. Sassi
      Hi All:
      I am having an issue with empty Menu Buttons in the Architron Plugin for C4D. Has anyone encountered this issue? See below. Thanks.
        Hi deep-sea,
        That would be a question for the developer of this plugin.
        The lwcad forum doesn't show that people have that problem.
        https://www.lwcad.com/forum/#
        Is your plugin compatible with the Cinema 4D version you are running?
        https://sites.google.com/view/architron/lwcad-5-x-cinema-4d-3dsmax/2-installation/1-minimum-requirements
        • D
          Hi Dr. Sassi,
          The plugin is the 2023 plugin from OTOY's website through which I have the subscription. Both C4D and Architron are the latest versions. I submitted a ticket to LWCAD so we shall see.
          Thanks.
            I hope there will be an answer for you, deep-sea.
            My best wishes.
            • Moved from Cinema 4D Assets & Plugins by  Dr. Sassi Dr. Sassi
            • D
              Thanks! Sorry for the late response. I contacted the dev and he said this occurred after the latest C4D update. Options are to revert back a few versions of C4D (which did work) or turn off empty boxes in the viewport in the Architron Settings as all the functions appear under the Attributes panel anyway.
              D 1 Reply Last reply Reply Quote
              • D
                deep-sea @deep-sea last edited by
                @deep-sea Also wanted to add that this will be fixed in the next major update of Architron.
                  Thank you for the update, deep-sea.
                  I hope your post will help others!
                  Fingers crossed, it will not take too long.
