    Rename Children of selected objects
    Cinema 4D Assets & Plugins
    • T
      truth-dream last edited by truth-dream
      With this script you can rename the children a null object, or any selection that has children inside, to match the parent's name + an incremental number, use in python scripts inside cinema. You can select any number of objects and it will rename the objects inside each parent to it's parent's name.
      This is very useful when importing AI layers that have many paths inside.
          # Get the active objects
          active_objects = doc.GetActiveObjects(c4d.GETACTIVEOBJECTFLAGS_CHILDREN)
          # Loop through each active object
          for obj in active_objects:
              # Get the name of the object
              base_name = obj.GetName()
              # Get the children of the object
              children = obj.GetChildren()
              # Loop through each child
              for i, child in enumerate(children):
                  # Rename the child with the base name and an incremental number
                  child.SetName(f"{base_name}_{i+1}")
          # Update the Cinema 4D scene
      # Execute main()
      if __name__=='__main__':
        Hi truth-dream,
        The idea of this forum is about the content provided by Maxon.
        Please check programming suggestions or questions in the Developer-Café.
        https://plugincafe.maxon.net/
        This is the correct place for it.
        I feel somewhat uncomfortable having code here, in general, for various reasons.
        The moderator of the Plugin Café is better suited for this.
