    [Help] Jonas Pilz Day 2 - Creating Spectacular Motion Graphics in Cinema 4D and Redshift
    Tutorial Discussions
    • M
      maxonadmin last edited by
      View Tutorial
      • Other
      • A
        aulvast-bat last edited by
        Hi Jonas,
        I followed this wonderful tutorial verbatim, but my cloth object does not fall through the hole. I tried playing with the geometry of the hole, the cloth (plane), the gravity, but unless I make the hole really really big, my cloth does nothing but that initial slump depression in the hole. I really want to recreate this project but I'm stuck. Any pointers or obvious issues. I'm using R2023 on a Mac Studio M1 Max. I have Greyscale Gorilla Plus installed if for some reason that matters.
        Paul
          Hi Paul,
          If Jonas had his laptop with him that day, I assume he worked on an M1 Max MBP. I have tried to reproduce it on the same model and also checked different releases. Somehow I run into the same problems as I believe you do.
          Please set up everything as he does (Leave Gravity as is for now), but try to increase the Sphere Field; that did the trick here.
          Here is my "follow along" file; while having also explored all options, I assume that Sphere Field adjustment is the way to go.
          CV4_2023_drs_23_SIch_11.c4d
          Image has SDS on it (default settings)
          If your problem is not solved, please share your file here. I'm happy to look into it, and if needed, ask Jonas directly next week.
          I found to rotate the Torus a little bit (R.H, animated) allows for better folding.
          My best wishes
