    Sweep Object and Redshift Issue
    redshift tile sweep even
    • A
      antonio_p3m last edited by Dr. Sassi
      Hello there,
      I would need help on the following setup.
      Basically, I need to put simple "arrow" texture on the Sweep Object, but I'm facing some issues while rendering with RS.
      You can see the artifacts on the "arrow" texture appear, screenshot is attached.
      Sweep_Issue.c4d
      Simplified c4d. project + arrow texture is attached.
      Help will be much appreciated.
      NOTE: Setup must be based on the Sweep Object setup.
      Thank you in advance,
      Antonio
        Hi Antonio,
        I see a different "tile" size for each arrow in the image. Besides, I get problems with the texture based on the settings.
        CV4_2023_drs_23_RSat_01.c4d
        You need to relink the texture for the file above.
        Here is an example that hopefully meets your needs. It creates first a rough but very evenly segmented Object. Then the RS Tag smoothed it.
        If that doesn't work, we might have to look into using a rail or other options as well.
        • A
          antonio_p3m last edited by antonio_p3m
          This post is deleted!
