    r23 and Corona Renderer
    corona installation legacy
    • J
      jury-sentence last edited by Dr. Sassi
      Hello, I've been trying to install Corona renderer 8 for Cinema 4D R23 (Windows) for a few hours, but I seem to be too stupid to do so.
      I've worked with the R20 so far, which had a plugin and everything worked great via the installer.
      R 23 does not have a plugin folder. In the R 23 I have specified a plugin folder in the search directory, but no matter whether the Corona folders are in the plugin folder or I use the installer, the error message "No installation path selected for this component. This may be caused by selecting plugins for software that was not detected on this system.
      Operation result: failed"
      Do you know a solution?
      sorry for bad english
        Hi jury-sentence,
        I have no idea if Corona 8 works with your setup and R23. That would be a question for the Chaos-Corona Support.
        https://support.chaos.com/hc/en-us/articles/4528608836881-Corona-for-Cinema-4D-Installation-Process
        R23 has in the Preferences an option to list plugins. (Option 1)
        If you are in the Preference, there is a button (Preference Folder) in the lower left corner. Press it, and it should lead you to the Folder that contains files for Cinema 4D. One Folder is called "plugins". You can place the Plugin into this. (Option 2)
        Again, I have no idea about Corona's system requirements for the Plugin you have.
        My best wishes
