    macros/actions recording in C4D ?
    script log action script uv editing
    • K
      kolodzick last edited by Dr. Sassi
      Hi
      Is it possible to record macros in C4D, like actions in Photoshop?
      I work mostly with imported CAD-data and with that I have to do some simple UV-editing over and over again.
      A one button solution would be a great time saver.
      Thanks🙂
        Hi kolodzick,
        There is not a simple Action Script like in Photoshop.
        As a rough rule of thumb, I would say if you can't put it in shortcuts, chances are low that there is an option to automate this. It's not an absolute rule but a guide.
        Please have a look at the Script View. Clear it before you do that specific step in the UV editor and see if that is recorded. I checked a few, and UV commands, for example, are not part of it.
        But if your steps lead to a record, you can copy and paste it into the Script Manager, save it, and create a shortcut.
        For anything coding, please check the Developer Forum:
        https://plugincafe.maxon.net
        https://help.maxon.net/c4d/en-us/?_gl=131pb7y_gcl_au*MTcwMDA3NjQxOS4xNjkwODU2ODIy#html/43049.html?TocPath=Extensions%2520Menu%257CScript%257C_____0
        • K
          Thank you Dr. Sassi!
            You're very welcome, kolodzick!
