    Pyro Caching
    pyro slow cache 1gb
    • I
      ideal-error last edited by Dr. Sassi
      Running 2024. Pyro caching is extremely unreliable and also randomly laggy as hell.
      This sim runs in the viewport at about 5 fps, yet takes anywhere between a couple of minutes to almost an hour (!) to cache frames. Is there a huge amount of data being cached that is not being processed for the viewport preview? This still wouldnt account for some frames ( see vdb files 198, 210, 215, 221 in the screengrab ) taking 30/40 mins sometimes.
      For a sim that is less that 500 frames long, that runs in the viewport at a reasonable pace, this length of time for caching is far from practical. I would be more than happy to discover I am doing something wrong!
      Here's the screengrab showing time taken for each frame:
      SCREENGRAB Imgur
      One assumption I am reaching is that the caching system does not use the GPU. Which is ridiculous, surely? I am running this on a 3090 and surely I should expect to see this GPU utilised for the caching process, not just the preview.
      • I
        Additional - it seems Pyro caches several frames at the same time. If I refresh the explorer window, I can see the file sizes for the last 5 or 6 vdb files increasing with each refresh. Would this again suggest this is being done on the CPU entirely?
          Hi ideal-error,
          If I read the data correctly, each frame has over one GB of data. This means if you expect to have that running in real-time, you would need something that has around 40GB/sec sustained reading speed available.
          This is only to access the data; rendering such data is slightly more demanding.
          I can't answer your question other than that. Screenshots, as I mentioned often, have very little information in them.
          Have you tried the 2024 cache options?
          https://help.maxon.net/c4d/2024/en-us/Default.htm#html/OPYRO-PYRO_OBJECT_CACHE_GROUP.html#3f40c3fc5076406ea1e226c46f758cd2
          If you have the feeling that something is off, and your setup should have the capacity to wrangle the data, then please get in touch with tech support:
          • I
            Hi Dr Sassi, thanks for the reply. I am not actually focusing on whether things run in real time - I dont expect heavy sims to do that. I am just comparing the preview in the viewport, running at 5 fps to when its time to cache the same sim, each frame takes an hour. I have used TurbulenceFD for over 10 years so I am fairly familiar with the sim/caching process, but I have never seen caching of sims take anywhere near this long, or cause this number of crashes. Am I to assume I should not be treating the Pyro system as a reliable one?
              Hi ideal-error,
              It sounds like an interesting case to study for the support and developers.
              Would you mind checking with them, as I have no other answer, and an hour per frame sounds like something support should take a deeper look at.
              My best wishes.
              • I
                Ok will do when I have some downtime - many thanks again, for all your work on here!
                  Thanks a lot, ideal-error,
                  For your patience with this case, and thanks for the kind feedback.
                  Have a great weekend.
