    Is Stage working in 2024.1.0 ?
    stage object 2024 camera
    • L
      let-fall last edited by Dr. Sassi
      Hello
      Camera doesnt change when stage is active. Is this bug or other thing?
      stage.c4d
      • P
        prompt-height last edited by
        Nope, I also wanted the ask the same thing. It seems to not work at all anymore. I will make a support ticket. If you also do the same, maybe they'll fix it faster.
          Hi let-fall, hi prompt-height,
          Thanks for the file.
          Was the Viewing Editor window was active?
          Please have a look here: (20 seconds long)
          https://stcineversityprod02.blob.core.windows.net/$web/Cineversity_Forum_Support/2023_Clips_DRS/Stage2024-1.mp4
          I have opened it in 2024.1, and all works fine here.
          What should work differently?
          As a side note, you could also use the Morph Camera and set the keyframes for the "Blend" as "Step".
          CV4_2024_drs_23_ANmc_01.c4d
          Screen Shot 2023-11-08 at 11.14.21 AM.jpg ![Screen Shot 2023-11-08 at 11.14.21 AM.png](Image dimensions are too big)
          If that doesn't help, I hope tech support will.
          • L
            Hi Dr Sassi,
            There is no bug when you drag the play with the arrow, but if you press the play button, there is no change.
            https://we.tl/t-3QYJoBoV3K
              Hi let-fall,
              I can't reproduce it here; it works for me:
              https://stcineversityprod02.blob.core.windows.net/$web/Cineversity_Forum_Support/2023_Clips_DRS/Stage_Play_Button.mp4
              I assume this is frustrating, so – thanks for your patience, the best way to solve that (fingers crossed) is to check with tech support:
              I hope they can replicate your setup (e.g., hardware, OS, etc.) and find what prevents it from working correctly.
              My best wishes
              • L
                Here it is a script to solve the problem. I'm waiting to solve this problem in the new version.
                https://www.patreon.com/posts/cinema-4d-2024-94100587
                  Hi let-fall,
                  What was tech support telling you?
                  I do not comment nor use 3rd party scripts.
                  If anyone uses it, please do so at your own risk.
                  Sorry if this sounds unfriendly, it was not my intention.
                  • L
                    Of course, I got it. Sorry for forgetting this is 3rd party script. I haven't sent the project to tech yet, but I just found it by chance.
                      Hi let-fall,
                      Thanks for the reply.
                      I needed to make it clear, as some scripts might harm users. This is not to say that I found the one to be questionable - again I do not even look into these. I do not take care of those; that would put too much on my plate. Anything coded and shared via link could be hacked or exchanged, altered after a while. Like any application running on open source, something I would not touch for a professional pipeline at all, as long as I don't know exactly what is going on. Thank you for understanding.
