    Bezier Curve Orientation
    • Pitchi
      Pitchi last edited by
      Hello, I don't know if the tool already exists but I would like to know if there is a way to automatically orient a bezier curve towards the next or previous key? In my animation, I would like to make an accelerated then linear then accelerated movement.
      Thanks you
      screenshot link : https://ibb.co/d6ds9zL
        Hi Pitchi
        If you like to have from the earlier Keyframe a straight line to the next Keyframe, do this:
        • Select the earlier Keyframe and go to the Attribute Manager.
        • Then, set this to Key Properties>Type> Linear.
        Please let me know if that works for you.
        • Pitchi
          Hi 🙂
          I mean, I would like to have a linear movement between 2 keys while keeping the bezier curve with the handles. There a tool for this?
          i made a video to explain : https://youtu.be/NTy3_2ZOUcE?si=XQGiY9UYfZg4bKIv
            Thanks for the screen capture, Pitchi,
            Creating a straight line between two keyframes requires setting both Bezier handles to look at each other. The path between up to four keyframes per track has changed if a keyframe existed before and after.
            The option to set a Constant Velocity will not do that either.
            But even after searching for a while, I could not find anything. Sorry.
            If there is a plugin, I'm not aware of it.
            The way to get your idea/request to Maxon is:
            "Share Your Idea".
            Include the video.
            • Pitchi
              Thanks you 🙂
                Thanks for the reply, Pitchi.
                If you submit your idea, I will support it, of course.
