    Different noise seed per clone
    • S
      smckenzie last edited by
      I have an object with a displacer as a child, and the object is then added to a cloner.
      The displacement is the same for each clone because the noise seed is the same. How do I get a different noise seed for each clone?
      https://www.icloud.com/iclouddrive/0755Z7ek258KXrdeQO5SvxEDQ#beams
        Hi smckenzie,
        Thanks for the file.
        Here is the simplest way, but if you need individual beams, Render or Multi Instances are not an option.
        CV4_2025_drs_24_RSdb_01.c4d
        If you need a lot, how many, and do they move? When would a repetition be visible (Number of beams)
