    default display color
    • Dutchbird
      Dutchbird last edited by
      How can I change the default display color in Attributes Manager?
      Cinema4D user since R8
      MacBookPro M1
        Thanks for asking, Dutchbird.
        Using the Preset pull-down in the upper right corner is the current and only suggestion; not fun, I know, which needs to be done pretty much every single time.
        That is your main target here: to have it done globally and for each new Project file by default.
        I don't like that you have to endure this. All I can do is write another report about this.
        It would help if you could voice this to Maxon as well.
        "Share Your Ideas"
        Thank you.
        • Dutchbird
          Thanks. I shared the idea.
          MacBookPro M1
            This is great, thank you, Dutchbird.
            I have shared a Report as well.
            Fingers crossed, this will work quickly.
            My best wishes
