    Boolean error¿?
    • C
      Capprim last edited by
      Hello Dr.Sassi!
      I'm building things for a game project. I found an error with a Boolean that I don't understand, as I have other segments of the same type, with no errors. Please take a look at this scene; I can't use booleans if I use slice to the object 02. However it worked in other objects like that, see 01
      Thanks for your helpBooleanError.c4d
        Hi Capprim,
        The answer is simple, the "From-To" parameters in the Slice Tab produce flipped Normals if the From Value is larger.
        Please have a look here.
        CV4_2025_drs_25_MOrn_01.c4d
        I have used a Revere Normal (Asset Browser> Operator> Reverse Normal
        If you take the Cylinder and make it editable [c], you can see it in Polygon Mode with active Polygons that this kind of Slice setting results in reverse Polygon Normals.
        I assume you want this object as a single Polygon Model for delivery. If that is correct, make the Cylinder editable, press the c key, reverse the Normals,
        Mesh> Normal, Reverse Normals, and then make the whole Boole Editable by using
        Object Manager.Object> Current State To Object function,
        or the C key again
        Otherwise, if your target allows for that, set the Cylinder as the one that is working and rotate it in place.
        With a little math, you could set up both in negative values. Then the "From-To" will work with the Boole, and keeps the Normals correct.
        CV4_2025_drs_25_MOrn_11.c4d
        Will this work for you?
        • C
          Hello! The normals were wrong! Now is fine! Thanks a lot!
            Thank you very much for the feedback, Capprim!
