    Mesh Deformer / FFD / Limitations - Suggestion
    feature-request character c4d cinema 4d
    • W
      wesware last edited by Dr. Sassi
      Hi.
      Anyone that has used the Mesh deformer for character work has probably run up against the limitations. 1. Cancelling out other deformers (FFDs and such). 2. Limitations with Pose Morph - Distorted Poses when the Cage mesh is deformed/rotated on an axis. Like a mouth shape that deforms in world space when the head is rotated.
      I would LOVE for Maxon to make the Mesh Deformer Cage act more like an FFD. Or make FFDs able to be a mesh. Perhaps that's impossible, but with most bendy/blobby characters, the behavior of a mesh-cage FFD would work much better than the Mesh deformer that needs to be initialized to the character.
      The mesh deformer could definitely use a facelift. (Pun... boooooo)!
        Hi wesware,
        Typically I need an example file. Perhaps next time. Thanks for considering.
        I have no idea about your setup, but try this:
        Instead of placing any deformer on the object with the Mesh Deformer, use the extra Deformers on the "Cage" itself.
        If you have a suggestion for Maxon, the channel is here:
        "Share Your Ideas!"
