    Viewport selection with nodes
    • AlexC
      AlexC last edited by
      Hello
      I've been teaching myself scene nodes, and have been trying to do some simple stuff with parametric objects and selections.
      One of the things that I find quite frustrating is that I haven't been able to figure out how to make selections based on a "region"
      What I'm trying to do is
      1/Select a few polygons (I can easily do this with the multiple selection tools by just entering their indices)
      2/Apply a subdivision
      3/Apply an extrusion to just that set of subdivided polygons
      Between step 2 and 3 of course my selection no longer works as the indices have changed.
      Is there a way to create something like a bounding box or a field that would "contain" any polygons within it, and make that a selection? That way I could subdivide and extrude in sequence without having to create a new selection?
      Thank you!
        Hi AlexC.,
        Please have a look here:
        CV4_2025_drs_25_SNse_01.c4d
        Node 1 - Select
        First I select polygon 3 and 4
        Node 2 - Subdivide
        Selection is set to "all"
        Node 3 - Extrude
        Selection is set to Default
        Is that what you are looking for?
        • AlexC
          Hello Sassi, I've been playing around with that approach, and it does work. Not exactly the way you set it up, but see my file. I think I'm still curious to know if there is any object or field or vertex map I could use to have a more interactive (rather than numeric) approach to making these selections, as turning the Polygon indices on and off is a bit tedious, but this approach does work!
          https://www.dropbox.com/scl/fi/s6w39calhdfb7e6dl08rr/WallNodeExtrude.c4d?rlkey=7lv3wolegr75ikb00ygqervtm&dl=0
          Thank you!
            Hi AlexC,
            How about this (press play)
            CV4_2025_drs_25_SNse_02.c4d
            Selections that are set in " " can be used, as long as the naming of the Selections is well done. Then you can use a Field and have the interactivity you might want.
            • AlexC
              Hey Sassi
              This is great! I forgot that you can add fields in selection tags...It is a bit hard to make it precise though, I find it very "on/off". I will play around with it a bit more, but this is a great approach, thank you very much!
                You're very welcome, AlexC.
                Yes, selections are like switches.
                Enjoy your weekend
