    Field Force (follow a curve)
    • R
      robertvoy last edited by
      Hello Dr. Sassi,
      Hope you're well.
      I have a very simple scene here: https://www.dropbox.com/t/fpztcYwh1jJBYo1S
      What I'm trying to do is make the ball follow more closely the curve using "Add to Velocity".
      I like the idea of controlling dynamic simulations with field forces with the "Add to Velocity" type, but I'm struggling to understand how to make it follow the force more closely.
      Thank you,
      Robert
        Hi Robert,
        Not to be lazy, but Jonas made a nice and clever short instruction on that theme.
        https://cineversity.maxon.net/en/tutorials/how_to_make_dynamic_objects_follow_splines
        A mix is needed to balance the effect of centrifugal forces. I used the term balance on purpose here.
        Enjoy.
        • R
          Thank you! That is using the "Change Direction" force type. Are you suggesting using a mix of "Add to Velocity" and the "Change Direction" field types with two separate field forces?
          I'm keen to figure this out using "Add to Velocity" instead of "Change Direction" to allow for more flexibility and more natural motion.
            Hi Robert,
            Please have a look here. Since the ball had no velocity, I used Absolute velocity first. The particles are more of an additional test, not needed.
            Example:
            CV4_2026_drs_25_SIff_01.c4d
            • R
              Thank you. Sadly, these are using the Absolute velocity, which gives the ball a constant speed. The reason I'm trying to work out how to use "Add to Velocity" is to achieve natural motion while being able to influence it more precisely. Is it possible?
                Hi Robert,
                Please have a look here:
                CV4_2026_drs_25_SIff_02.c4d
                Animate the Force Field Strength to your liking. You will have full control over the velocity. (I accelerated the sphere, stopped it, and accelerated again). If you need a constant add, set the numbers accordingly; it will interpolate very precisely.
                • R
                  Hello Dr. Sassi,
                  Thank you for that. I eventually figured this out, thanks to a clue you provided.
                  For anyone looking for a solution to this, here is the project file:
                  cv4_2026_drs_25_siff_03.c4d
                  The key is to have a copy of the spline, which creates a force pulling towards itself, to counteract the centrifugal force.
                    You're very welcome, Robert,
                    Yes, as Jonas showcased it.
                    Have a great weekend
