    Field Force with Vertex Map
    • MaverickMongoose
      MaverickMongoose last edited by
      Hi Dr Sassi,
      Is it possible to use vertex maps with the Field Force?
      I've made a growing round logo animation in a vertex map and I want some rocks to be attracted to the yellow part as it grows. I put the vertex field into the Field Force but no matter what I try it has no effect. If I put a spline or an object in there instead of the vertex map it works fine.
      Heres my file, any ideas? https://we.tl/t-gpQg6TIRQ4
      Also the FREEZE modifier in fields is the most frustrating thing ever, constantly breaks and needs to be readded - the clear and freeze buttons seem to do nothing as well which you would think would easily reset the Freeze, am I doing it wrong?
      Do you know if its possible to grow the freeze from nothing? Im using a spherical field but I dont want it to start straight away, but I cant seem to grow from nothing.
      Thanks again!
        Hi MaverickMongoose,
        I'm not aware that a Vertex Map can provide a direction for the Force Field object. What direction would have a Vertex map with all points set to the same value?
        I would use it in the Fields tab and in the Object tab, setting an object that allows for providing any directional information, such as a Linear Field or the Volume Object with added object(s) and set to Vector.
        (In your file: You have Vector information inside the Vertex Map> Fields, but when you open the Hierarchy, the Direction Indicator [the arrow] is not given to the Sphere).
        Here is your file back (Press Play)
        https://projectfiles.maxon.net/Cineversity_Forum_Support/2025_PROJECTS_DRS/20251010_CV4_2026_drs_25_SIvm_01.c4d.zip
        • MaverickMongoose
          Great, if I just make the Field Force a negative value instead, it kinda does what I want. Thanks for that!
            Thanks for the feedback, MaverickMongoose.
            I'm glad you found what you needed.
