    [Help] Modeling the Splines and Generators
    Tutorial Discussions
    • M
      maxonadmin last edited by
      View Tutorial
      • Other
      • F
        FaustBleu last edited by FaustBleu
        I think using Cloth Surface for thickness like this video (14:00) has issues. I'm around chapter 15 and start giving objects PBR materials using OctaneRender, the refraction of the fishbowl is wrong no matter how I tweaked the renderer, then I found by using positive values in Cloth Surface's Thickness parameter solves the issue. In the end, I recreated the fishbowl with splines with what I've learned from this series, and I found it more intuitive and precise, and it works pretty well when render. I absolutely love how this series cover as many tools as possible, but I just think choosing this tool for this purpose may not be optimal.
          Hi FaustBleu,
          Yes, indeed, Octane would require a different tutorial.
          For a while, Cinema 4D offers the Thickness Object, perhaps worth a shot.
          Thanks for the kind words.
          My best wishes.
          • C
            committee-tear last edited by committee-tear
            Screenshot 2024-03-20 at 3.44.53 AM.png Great tutorial! I am new to Cinema 4D and am learning from Getting Started with Cinema 4D. I am in chapter 6. and I have three questions:
            1. The perspective window, the grid is in the wrong direction; how can I adjust the grid?
            2. I can't scale or rotate the crab. The center of the scale icon is not activated. It's gray. How can I fix the issue?
            3. I copied and pasted all the parts into a new document. Now, when I scale the crab, all the parts scale up individually, and you lose all the proportions. in the image, the pupils disappears. How can I fix the issue?
              ![Screenshot 2024-03-20 at 3.45.35 AM.png](Image dimensions are too big) Screenshot 2024-03-20 at 3.45.35 AM.png !Screenshot 2024-03-20 at 3.45.20 AM.png
              Hi committee-tear,
              When I open the downloadable file, I sometimes have to press the T or R key twice to get Scale or Rotation. I have no idea if you have that as well. Perhaps that is the problem?
              To make that easier for you, I have recorded a 60-second clip.
              https://stcineversityprod02.blob.core.windows.net/$web/Cineversity_Forum_Support/2024_Clips_DRS/20240320_06_Crab-Bowl_Scale_Rotation.mp4
              The grid should be OK; if not, go to the menu directly over the editor Perspective window:
              View> Frame Default.
              Does this help?
              Scale
              Click in a space when the Scale tool is active. Press the T key once; in any of your images, the Move tool is active, not the Scale tool. Make sure the Top Null (Crab-Character) is selected, not the Sphere that is the Crab-body. Click and drag. The Crab is built out of Primitives, and they behave a little bit differently than Polygon objects. It is not essential for this lesson, but be aware that more will come.
              Rotate
              Press the R key once (or use the icon)
              There should be a change, and three circular bands should show up.
              I hope the little video helps.
              Please let me know how it goes.
