    AEC not importing lights or nulls
    c4d cinema 4d aec after effects null
    • S
      schnoidl last edited by Dr. Sassi
      hello, I am trying to export a scene via AEC with lights and nulls. have assigned Cineware tag to nulls, lights are set to export. Only camera comes through.
        Hi schnoidl,
        I have tested it here with Cinema 4D 2023.1 and AfterEffects.
        Yes, I get that if I have an older plug-in installed. Using the newest that is supplied with the 2023.1 version, I have no problems. I tested Ae 22 and Ae 23.
        The output setting is set to all frames, and 3D is also checked (these are the two things, besides the plug-in, that have caused problems in the past.
        Example with 3 Nulls, three lights, and a camera. The camera, plus one null and one light, is animated. This should indicate if it is on the Cinema 4D side or in Ae.
        https://www.dropbox.com/s/asjc1vczhy5yc10/CV4_2023_drs_23_AEec_01.aec.zip?dl=0
        Workaround: save the whole scene (or create a new one with just these settings and items) and save it as Cineware, then extract those from Cineware in Ae.
        Other than that, I can only suggest Tech Support. But I assume that is something that requires an update.
        Enjoy your Sunday.
        • S
          thank you
            You're very welcome, schnoidl.
            If there is any question left about aec, please let me know.
            My best wishes for your production.
