    Cloth simulation travel in a circle
    simulation cinema 4d c4d vfx motion graphics
    • H
      Hoi last edited by Dr. Sassi
      Hi all,
      What is the best way for a cloth simulation to follow a circular path with turbulence force? Any suggestion/help will be greatly appreciated.
      Thanks,
      Hoi
        Hi Hoi,
        Please have a look here:
        https://www.dropbox.com/s/f3q7z6g2lu16uy1/CV4_2023_drs_23_SIfw_01.zip?dl=0
        I would suggest caching the Cloth.
        Please note that I have set the Gravity to zero.
        There are many ways to do it, but I hope the scene's elements help shape the illusion.
        (The simple version would be to use a Belt and animate a collider object as the "belt".)
        Enjoy
        • H
          Hoi last edited by
          Hi Dr. Sassi,
          Thank you for the file and suggestion. Never knew you can change volume builder to vector and use it as a field. That will open a lot more experimentation. As for this example,
          I end up exporting the cloth as alembic with turbulence and, align to spline the alembic cloth to travel in a circle path.
            You're very welcome, practice-boss.
            Yes, there are many ways to do it, and Forces are just one of the powerful options.
            Enjoy
