    Node Deformer Crashing the system
    support cinema 4d c4d
    • E
      EmTek last edited by Dr. Sassi
      Not sure if this is a bug, but using a Geometry Axis Node with a cloner repeatedly crashes C4D. Is there a more optimal way to use the Geometry Axis with a cloner?
      C4D v. 2023.1.3
        Hi EmTek,
        Sorry that you have trouble.
        Please get in touch with Support, and share the file with them.
        Tech Support
        From what I can see, the partial view of the OM, I can only re-create something that is not crashing. Images do not tell a lot, Project files often do a much better job.
        My way would be to have the Cube as a child under a Null.
        Enjoy your weekend
        E 1 Reply Last reply Reply Quote
        • E
          EmTek @Dr. Sassi last edited by
          @Dr-Sassi Thank you, i will reach out. It was happening in my project, so I tested it out in a new, fresh scene with default settings and default objects and the issue still persisted...even reset my system.
          This is all thats in the scene. STAGE is the root null, but the issue mostly happens if i modify any of the settings of a cloner that is a parent of a primitive with a geom axis as a child.
            Hi EmTek,
            Thanks for getting in contact with Tech Support.
            I can't do anything from images, especially those that don't show the whole, as the vertical line (left) indicates. There is a little green dot, which indicates there is a Generator outside of the image frame.
            I hope you get the answer ASAP that you need.
            My best wishes
