    [Help] Introduction to Fields
    Tutorial Discussions
    • M
      maxonadmin last edited by
      View Tutorial
      • Other
      • Dutchbird
        Dutchbird last edited by
        I was watching the "Walking Through Fields: Triggering Animation:" but its totally different in R2023.
        I tried the cloth in Mograph Cloner but it doesn't work.
        Cinema4D user since R8
        MacBookPro M1
          Hi Dutchbird,
          As for those earlier released tutorials, you must use the Legacy Solver options in the Cloth Sim. (I haven't tested it this way, though.)
          Yes, that should be updated.
          Sorry for the trouble.
          Enjoy
