    Spline Extrude/Sweep
    sweep extrude spline
    • S
      smckenzie last edited by Dr. Sassi
      I have a spline that I've pulled from an old 3DS Max scene, it represents a stair case. The original object had a lot of non-planar polygons, so I pulled a splined to extrude it to make a new version.
      Issue is many of the vertex's aren't aligned correctly. Apart from manually aligning them via the Structure manager, is there a quicker way of achieving this?
      vertex alignment.c4d
        Hi smckenzie,
        Please have a look at the file below:
        https://www.dropbox.com/s/j56xmd030cigjli/CV4_2023_drs_23_MOes_01.c4d.zip?dl=0
        I have created two options to create the wanted geometry.
        Cinema 4D has no functionality to create from a single closed Spline object geometry as requested.
        In the file, I have used the short CSTO, which I use in files to indicate that I have used the Object Manger> Object> Current State to Object.
        • S
          The FFD option is great, thanks again!
            Thanks a lot, smckenzie, for the feedback. 🙂
            I also like that you open for each subject a new forum thread; very much appreciated!
            Let me know if there is anything else. I'm happy to look into it.
            Cheers.
