    Xpresso that has a switch to control the Output width and hight?
    render settings fast switch presets
    • O
      object-kind last edited by Dr. Sassi
      Hello, is it possible to set up a null with Xpresso that has a switch to control the Output width and hight?
      I want to set up a template the has different aspect ratio's and can switch output sizes from one to another, like 16x9, 9x16, 4x5 and so on.
      Many thanks!
        Hi object-kind,
        Why not use Render Settings Presets, perhaps the Takes System?
        Typically it is easy to say that if a parameter is not animate-able, one can't use it in XPresso. To use the Set Driver, Set Driver Expression might give you the node, but it might not work. In the case of render settings, it won't.
        Another way is to use the Script-Log and set up shortcuts via Python. That would be the case for the Maxon Developer Café forum, as I do not handle Phyton scripting here.
        https://developers.maxon.net/?page_id=1114
        • O
          God idea about the Take system!
          Thank you!
            Great. 🙂 Thanks for the reply, object-kind.
            Enjoy!
