    Dope Sheet Issues 2023
    grayed out dopesheet parameter timeline
    • C
      collar-significance last edited by Dr. Sassi
      Need some help ! re 2023, Can anyone explain why keyframes are not showing up in my dopesheet .. tried every menu to find the hidden problem but for the life of me I can't work it out now, at first I thought it was because I autokeyframed somethings, but happens even with the radio buttons, the objects appear in the dopesheet menu, so c4d does know what has been keyframed and the animation plays but I cannot figure out why the buttons are greyed out and why I cannot see any keyframes ? Ive tried dragged the objects to the dope sheet still nothing .. driving me a bit crazy
        Hi collar-significance,
        It sounds like the Take System is enabled, and you are not working in the Main Take.
        This is often the case when an FBX is loaded and the import "alert" is clicked without reading it.
        If that happens even in a new project file, please animate a cube and share that file.
        So I can take a look at it.
        Otherwise, please get in touch with tech support
