    Mospline random values with formula
    mograph mospline randomness
    • Fluidmotion
      Fluidmotion last edited by Fluidmotion
      I am experimenting with Mosplines. I would like to have random lengths for each segment and I achive that. But random values change everytime I restart the App, toggle the object on or off, or even change the name of the Mospline which makes it impossible to work with 🙂 Is there a way to get constant random numbers and change the seed whenever I need it? And to be able to remap these values would be cherry on top! Thanks. MoSpline_Random.c4d
        Hi Fluidmotion,
        Thanks for the file!
        I usually place the rnd(value; seed) into Formula fields, like rnd(123;456). However, if stable results are required, I can confirm that this is not working with the MoSpline.
        I have to file a report about it.
        Two option. Place a Create> Spline> Empty Spline into the Destination field, and at the exact moment you have a setup you like, switch the MoSpline off. Perhaps even clear the Destination field.
        Of course, the Object Manager> Object> Current State To Object will do the same. But if the Spline (Segment) is used somewhere else, the CSTO option requires connecting the new results.
        Setting it up via a Cloner and a Random Effector (set to Random Indexed) might allow for some workaround.
        CV4_2023_drs_23_MGms_01.c4d
        I'm curious what the reply to the report will be and if a fix is soon available.
