    Vertex map for Pyro
    pyro artdirect vertex map
    • AlexC
      AlexC last edited by Dr. Sassi
      Hello
      Is it possible to use a vertex map (or even a polygon selection) to drive a Pyro simulation ?
      I don't see any option to do that within the Pyto Tag or Pyro Output object.
      Thanks!
        Hi AlexC,
        Please check the interface; there are these little > icons to twirl it open, when open they are v shaped.
        https://help.maxon.net/c4d/2023/en-us/Default.htm#html/TPYRO-ID_TAGPROPERTIES.html#PYRO_TAG_DENSITY_ENABLED
        • AlexC
          Thank you Sassi!
            You're very welcome, AlexC.
