    How to rotate objects together within the same Voronoi Fracture
    voronoi fracture rotation clones
    • D
      deal-cake last edited by Dr. Sassi
      Hi! I am stuck on this rather simple task in Cinema 4D and not sure how to get out:)
      Basically I am trying to spin each cube of the below row of cubes, around its axis, together with each letter that sits on each one of them. I want each letter to spin together with each cube and not around its own axis as it's currently happening. To create the spin I animate the R: H of the Transform tab of the Voronoi Fracture. I am actually planning to have two letters on each cube one on the front side and one on the back and as they rotate the letters at the back get revealed. I have only done the first set like this and I even used a Null object but with no luck. Any help much appreciated!p03.png p01.png p04.png
        Hi deal-cake,
        Please have a look here:
        CV4_2023_drs_23_MGvr_01.c4d
        Switch the Sources to off if that is not needed.
        Working with a project file is my preferred way, and please, more data, e.g., why do you use the Voronoi Fracture - what is the target? This helps more than images. Just to save you some time.
        • D
          Thanks for your reply! Your question made me think if I should just use the Fracture object instead and this seems to have solved the problem. I didn't realise there is the option to attach a project file. I will do that next time.
            Hi deal-cake,
            Thank you for your reply. Yes, knowing more about the project's target helps.
            Project files help a lot; at least I can "read" those more in-depth than images, as I have explored uncounted of them, and it is often a little hint that triggers perhaps an unexpected solution. I hope that makes sense.
            Files are limited here to around 1MB.
            Anyway, let me know if you have any questions.
            • D
              Apologies for late reply, I hadn't realised you had sent me a c4d file with the solution, even using Voronoi Fracture. It's exactly what I was looking for to do. Thanks very much!
              • D
                Fracture object worked fine too, but it's good to have the solution with Voronoi, I will study it for learning purposes.
                  Thanks for your feedback, deal-cake.
                  I'm glad it is useful for you.
                  Let me know if there is something else. Please for new themes, a new thread.
                  Enjoy your weekend
