    Point cloud with color from 3D model?
    point cloud redshift 3d
    • S
      savings-chest last edited by Dr. Sassi
      Trying to create a scene with point clouds from a pre-existing asset. Using attom array or cloner, I am able to get the spheres on the points of the object but how do I then transfer the object's color data to these points? Trying to get something like the pic below.
        Hi savings-chest,
        Please have a look here:
        CV4_2023_drs_23_MGpc_01.c4d
        Sphere Size and Bloom can be adjusted of course, over the top here to make a point.
        Is this working with your data? I have nothing from your side to explore it, so it is hard to tell. I love project files to answer here.
        S 1 Reply Last reply Reply Quote
        • S
          savings-chest @Dr. Sassi last edited by
          @Dr-Sassi Thank you so much for your reply! I sadly keep getting "failed to allocate necessary gpu recyclable memory. Aborting the render" even after having reduced all CPU, GPU memory settings. Perhaps you could tell me the steps I can take to go in this direction. I have a model with 5 colors on it and I want that color data to transfer to my point cloud.
            Hi savings-chest,
            Not my favorite line to share: Have you restarted Cinema 4D?
            When I get this line, I have found no better way than this. Perhaps Tech Support can give you a better answer while having more specs from your setup. Nothing that I am supposed to do here.
            I dragged the Point-could object into the Matrix Object.
            The Vertex Color went into the Shader Effector> Fields
            The Shader Effector> Parameters> Colors: Fields Colors
            The Shader Effector goes then to the Matrix Object
            The Matrix Object receives and Redshift Render Tag, set to particles: Sphere Instances
            The RS Material needs a User Data Color, while the Input Attribute is set to RSMGColor (Use the Preset button for this)
            The Matrix Object gets this RS Material
            Set up a Light and camera to your liking
            Save early, save often
            Perhaps try it with a small object first.
            Please, let me know how it went.
            Enjoy
            • S
              I am getting an all black point cloud with my object but the file you sent had a torus which had a red, green, yellow field. Is that the UVW mapping or was your material red, green, yellow?
                Hi saving-chest,
                The colors come from the Vertex Tag.
                https://help.maxon.net/c4d/2023/en-us/Default.htm#html/TVERTEXCOLOR.html
                I do not have your file here, so I can't tell what is happening on your side.
                How did you create the file, where did you get it from, and what does the color have as its origin?
