    clones-fading?
    mograph visibility gradually fading
    • C
      channel-blame last edited by Dr. Sassi
      Hi Dr. Sassi, how are you? a while back you created a rig for me, where by, when a plain effector passes through cloned spheres, for example, some of the clones fade in, then fade out-please see attached file; with the plain effector, they "pop" visible, and "pop" invisible , I can not get them to "fade to visible" then "fade to invisibleclones-visible-invisible.c4d "; what am I doing wrong?, thank you in advance, Craig
        Hi Craig,
        Thanks, I hope you are doing fine!
        The Visible checkbox offers visible or not; there is no transition. This needs to be done with Field Color, for example.
        Is this more what you are looking for?
        CV4_2023_drs_23_MGff_01.c4d
        • C
          this is it!!-yes, ! the clones fade , as I was hoping; can I presume that this can be done with RedShift?, thank you sir
            Thanks for the feedback, Craig.
            Here is the RS version, I should have included it. 🙂
            CV4_2023_drs_23_MGff_02.c4d
            Set the UserData to MoGraph Color.
            • C
              no worries, thank you for your efforts! -Craig
                You're very welcome, Craig.
                My best wishes for the project!
                • Referenced by  WShawn WShawn
