    Illustrator invisible splines not importing
    illustrator import version 8
    • R
      raise-trade last edited by Dr. Sassi
      I only get vector information that has an appearance like a fill or stroke. But C4D corrupts the information. I don't want fill or stroke information. How do i import the old fashion way with illustrator 9 files? it doesn't seem to work anymore.
      Thanks for your help!
      P.S. I can't upload screenshots because the dimensions are too big and I can't upload AI files.
        Hi raise-trade,
        The version you need to use is Illustrator 8. Nine already had more information in it.
        Any newer file might be opened in the Newer options: Vector Import; if you have that and no Illustrator 8 file, then you can click on that green icon and press the c key. Open the hierarchy, and you will find all "Splines" in it that were used to build the shapes.
        I checked it in 2024.0
        • R
          ah, ok, thank you!
            Thanks for the reply, raise-trade, and for taking the time.
