    Did Surface Scaled BlueNoise change in R24?
    blue noise scale change
    • AlexC
      AlexC last edited by Dr. Sassi
      Hello
      I'm trying to follow this tutorial by Noseman here
      https://www.youtube.com/watch?v=F82AuduoN_g
      But when I set it up the way he did, I have no result at all. Is there something that could have changed in the new release of C4d? I'm using 2024
      https://www.dropbox.com/scl/fi/acpik6pv7v1onghs8qloe/SurfacePacking.c4d?rlkey=2uk40ow6tj14f3fjfxx8fbb9o&dl=0
      Thanks!
        Hi AlexC,
        It didn't change, I asked Noseman, just to have a first hand information for you. Would you mind sharing your file (last iteration), so I can take a look.
        • AlexC
          Hello Sassi
          The project file was in my post, here it is for ease : https://www.dropbox.com/scl/fi/acpik6pv7v1onghs8qloe/SurfacePacking.c4d?rlkey=2uk40ow6tj14f3fjfxx8fbb9o&dl=0
          Thanks!!
            Thank you, AlexC.
            I did the tutorial three times just to see if I got the same result, and going through it at one point, I missed this step, which led to the same result you have in your file.
            https://www.youtube.com/watch?v=F82AuduoN_g&t=114s
            Funnily, it happened to me the second time while I thought I had all the steps. I mention that as it is so easy to miss one step, as I have seen it over the years in questions here.
            The best way for me is to watch and write a list of steps down. Because that list is faster to reproduce, I can put checkmarks on it. I have wondered for a while if such a list at the end of each tutorial would be supportive.
            Here is your file with the edited two ports to the Object back
            CV4_2024_drs_23_NEdc_02.c4d
            • AlexC
              Ah!!! Thanks so much Sassi, indeed a small mistake but a critical one.
              Thank you again!
                Thanks for the reply, AlexC.
                Yes, I guess it is something that is only too common. I believe there should be something on the training side to improve that. I will explore this phenomenon.
                This simple setup should be a ready-to-use Capsule in the Asset Browser. I have no idea why Noseman has not placed it there already.
                BTW: Have you used a Sphere as the first object? 🙂
                My best wishes
