    Uv problem with loft
    loft texture problems
    • Xavier Solans
      Xavier Solans last edited by Dr. Sassi
      Hi everyone.
      I have a problem with this texture. As you can see, the line does not flow through the loft. There are like hard edges in the lines and I no idea how to fix this problem.
      My only option is to make editable the loft amb fix the uvs manually...
      alt text
      Thanks in advance.
        Hi Dorna Sports,
        What I need is the project file. Images show the problem, but more often than not, the source of it. What are the settings of the Loft or the splines?
        Will increasing the parameter Subdivision V change the outcome? This would be my first test with such a file.
        • Xavier Solans
          Hi Dr. Sassi.
          Loft Uvs problem.c4d
          This file have the same issue. I tried to increase the parameter Subdivision V, but the problem remains.
          I'm out of options...
          Cheers.
            Hi Dorna Sports,
            Thank you very much for the file!
            Please have a look here.
            CV4_2024_drs_23_MOfl.c4d
            Would that work for you?
            I have used the MoSpline to provide all Spline with equal vertices.
            This relaxes the structure of the mesh much more. At the same time, you keep the flexibility of the Primitives alive.
            • Xavier Solans
              Dr. Sassi...
              THANK YOU SO SO MUCH !!
              We had this problem for over a month and nobody could found a solution.
              Me and my team are extremely grateful to you.
              Cheers and thank you again.
                Thank you very much for the kind feedback, Dorna Sports!
                This makes my day. 🙂
