    Need Help with Animation
    rolercoaster animation spline
    • B
      branch-drunk last edited by Dr. Sassi
      Greetings.
      I wonder if someone could give me a little advice how to setup a Special Animation.
      I have some Dragon Rigs and i want to animate a Flythrough Seqquence.
      The Problem is how can i Set the Mesh to two Null Points and how to Animate them.
      If i use Splines i have to fix a Null Object to the Spline. But how to make the Rotation and the Drifting of the Dragon ? If my Dragon takes a Turn and he is very high he will move teh Rotation of the fixed Null. The rotation would be hard.
      On the other Side, if i just move the Dragon along two Move Keys it would work if he is flying straigt. But how to handle if he turns Manouvers ?
        Hi branch-drunk,
        To use two Nulls, the Target Tag will work; eventually, you might need a third Null (Up-Vector) to avoid problems.
        Below is a Spline-based solution with a Rail. The Rail field will be available after you enable the Tangent Check box.
        CV4_2024_dr_23_ANrt_01.c4d
        Is that working for you?
