    Lights in Cloners are broken in 2024
    2024.1 cloner lights workaround
    • F
      Frischvergiftung last edited by Dr. Sassi
      Hi!
      Lights in Cloners dont seem to work anymore. They render in the Viewport, but not in the Picture Viewer.
      Running 2024.1.0 // Using Standard renderer.
      Same scene works perfectly well in 2023. Is this a bug?
      Thanks, Max
        Hi unique-foundation,
        Yes, I can confirm this. Sorry for your trouble. EDIT: workarounds below /edit.
        Are these lights static? Then press the C key, and it renders.
        If you need to have it animated, please share the small setup from the image, and I will try to find a workaround. Typically, Xpresso should do the trick.
        Again, it's not fun, but I can't tell you more now.
          P.S.: After some trial and error, I hope I found a workaround; since your image showed white lights only, please try the following
          Place the light under a Null, then the Null under the Cloner. Render, as the editor shows only a few lights.
          CV4_2024_drs_23_MGli_11.c4d
            P.S.2.: Here are two workaround ideas for Color based lights.
            CV4_2024_drs_23_MGli_21.c4d
            CV4_2024_drs_23_MGli_31.c4d
            • F
              Oh Wow, thank you! Yes, putting them in a null helps. Thanks! Also for the other Setups. I guess this will be adressed in a patch soon, as this will come up for a lot of users. Thanks Sir!
                Thanks for the kind feedback, unique-foundation!
                Yes, I assume that will bother many people, but we can significantly ease that problem thanks to your question. Thank you!
