    Voronoi Shatter showing before collision
    bullet rigid voronoi fr
    • U
      unique-calm last edited by Dr. Sassi
      Hi there,
      I'm using Cinema 4D 2024.1.0 and I have created a voronoi fracture (a glass window) and it is showing the fracture marks before the collision takes place even though I have selected the trigger to be on collision. Is there any way to remedy this?
      Thanks in advance!
        Hi unique-calm.
        Please have a look here.
        CV4_2024_drs_23_DYvf_01.c4d
        (I moved the camera, so it is easier to observe.)
        I have set the distance "Size Increment" to -1cm. I need to see your file to know if that will work for you. Each scene is different.
        Brainstorming: Leaving the Voronoi Fracture object off until it hits the object might help. If not, render two passes and roto/blend between the two if Motion blur and camera motion are not eating the seems.
        • U
          Thank you!
            You're very welcome, unique-calm!
            Have a great weekend
