    Steel Grating
    grating bevel rs proxy
    • G
      gain-concern last edited by Dr. Sassi
      Hello everyone
      I'm currently trying to create a grating in C4D.
      When building the 3D model, I thought that I could create the grate using a material so that my file wouldn't be too heavy. That's why I built the grate in a simplified form as a cuboid. Unfortunately, the rust now only appears on the outer edges of the rectangle and does not become a grating as hoped.
      Is it possible to create the grating using C4D and a material or do I have to build the grating directly in the 3D model?Bildschirmfoto 2023-11-21 um 10.27.59.pdf
        Hi gain-conern,
        The pdf is not uploaded. Have you tried to use a Bevel on your model?
        Images, like screenshots, are best as jpg and below 500 pixels in height.
        QT
        https://youtu.be/qKOZ7Mk1SJ0?si=thW1Zwgc7qLTZfHD
        If you can, share a cube (to scale) of your model with the material you have so far. Any c4d file below 1MB will work here as an upload.
        G 1 Reply Last reply Reply Quote
        • G
          gain-concern @Dr. Sassi last edited by
          @Dr-Sassi
          Grating.c4d
          Hello Dr. Sassi
          In the attachment I am sending you two pictures for explanation.
          Attached is the link to the grating in question:
          https://abload.de/image.php?img=screenfoto2023-11asfig.png
          Attached is the link to the perspective:
          Image: perspektiveh7i6f.png - abload.de
          The file with the block and the material is also attached.
          I am wondering whether it is possible to create a material that ultimately looks like this:
          https://www.shopmetal.de/foto/upload/gr.jpg
          • G
            gain-concern @gain-concern last edited by
            @gain-concern
            https://abload.de/image.php?img=bildschirmfoto2023-11asfig.png
            https://abload.de/image.php?img=perspektiveh7i6f.png
              Hi gain-concern,
              Perhaps use the RS Object Tag> Particles, with the MoGraph Matrix, to get these detailed results without any render bottleneck.
              I have used a simple material, but the key is that the Noise is set to World like the Zink-coating would look with that Grating.
              Render the scene, and you should notice how fast it is.
              CV4_2024_drs_23_RSgr_02.c4d
              Two objects are available, beveled or simple.
              As a side note:
              My initial tip with Bevel was based on the guessing (missing the image) that it was perhaps based on the German term "Grat" (English Burr). Before I studied Architecture, I went to a Metal/Electric school, and in our practical assignments, we had to get the Grat (Burr) off the Steel edges. (entgraten).
              Since I have gotten questions from all over the world in the past two decades, I often have to go with a guess. But yes, your term was absolutely correct.
