    Laser light
    laser light
    • P
      Pim last edited by Pim
      Hi, I have been to a great popconcert where I saw these beautiful laser lights!
      I tried to create that same laser effect in Cinema, but I am not sure how to do it.
      Initially I though to put a light in a closed cube with only a small hole in it.
      That works for a single spot light with a very small beam.
      If I use a area light (a rectangle) and put it in that same closed cube with the whole, I expect to see a small but broad beam of light.
      But that does not seem to work.
      What am I doing wrong?
      Regards,
      Pim
      first test.c4d
        Hi Pim,
        Please have a look here.
        CV4_2024_drs_23_LIlz_01.c4d
        Your scene was set up with the Standard render. Render to Picture Viewer to see the result.
        To get the typical laser light, I have used a specific Motion Blur. See image.
        There is a second light if you like to have more impact on the surfaces
        Let me know if that is working for you.
        • P
          Pim last edited by
          Beautifull. Long render times, but I decreased the number os samples in Sub-Frame Motion Blur.
          Thank you.
            You're very welcome, Pim.
            Thanks for taking the time.
